Replacement suspension recommendations
  • Thread starter Thread starter JamesR913
  • Replies Replies 1
  • Views Views 439
JamesR913
I have a 2019 DCLB Off road with 112k miles on the original suspension. I'm starting to feel some bump steer so I think it's probably time to replace the suspension components. I'm not looking for a big lift or anything and I don't get to go off-road. I'm thinking about some 5100s but not really sure if I should just stick with stock or if there's appreciable improvements day to day from upgrading.
If you are willing to spend a little more, I would get a Billstein 6112 complete assembly in the front and get a fresh set of springs and a significant upgrade. I would recommend replacing the rear shocks at the same time I personally would pick 5160s for the back. These would give you a significant improvement in your shock setup and work really well for a daily driver type of setup.
The 5100s you mentioned are also a great choice at a smaller price point.
Nothing wrong with refreshing your suspension with new Toyota OEM parts either. I personally like to upgrade a bit, when possible, but that is just me.
I hope that helps you. There are a lot of great options for our Tacoma's.
