I have TRD OR and it doesn't have push button. I prefer it that way but I still like the idea of a conversion kit.I asked the Dealer before the purchase and they told the SR and SR5 did not have Push Button start, but the TRD did.
I was hoping for an aftermarket kit would exist and surface.
Sure about that? I thought there was a small, completely weather sealed piece that didn't emit anything unless it was "checked" by the sensors inside the truck. I've messed around with aftermarket key fobs, and there's a little sunflower seed sized piece that does the push button start sensor duty, but no battery or connection to a battery that could "constantly transmit."One big problem with the push button start is the key fob emanates a signal with a code that is recognized by the truck. The fob is broadcasting this signal at all times. Thieves can scan to pick up the code then recreate code on another aftermarket fob. At that point they can walk up to your truck open the door and drive off with your truck. If you leave your car in a parking lot or a driveway it is susceptible to this kind of theft. You can turn off the fob from sending the signal so it isn't broadcasting at all times, but then it is a set up like the older version of a key and fob. If I had the choice I would stick with the tried and true key with fob where you need to push the button to get into the truck.
