Psi
  • Thread starter Thread starter Ed w
  • Replies Replies 3
  • Views Views 687
Are you asking what pressure you should inflate that tire tire to? Are they P Metric, D, or E rated? What size? Typically you would inflate to spec but if they are 10ply and the sidewall calls for 80lb you'll rattle your kidneys loose at that pressure. I run my 10plys at 35 front and 40 rear after I established proper tread contact
