OV Tune 2.0 - Arizona
mobileantics
Authorized VF Tuner
Hey all, my name is JT and I am a VF Tuner Pro Tuner based here in Phoenix, AZ. If you are tired of the way your truck drives, I offer the YotaWerx Tunes, which are enhanced versions of the standard vF Tune v2.0. These tunes have been enhanced for: increased low-end power, consistent and predictable throttle response/input, significantly improved shift logic with smoother shifting, smoother power delivery, and elimination of low RPM dead pedal.
The tune is offered in two different flavors:
a. Active Duty - For aggressive drivers and/or heavier trucks with more weight
b. Weekend Warrior - Primarily for stock (or close to) trucks, or more casual drivers
I’ll first check to make sure your truck ECU ID has the latest TSB update; if it doesn’t I’ll update it for you (that’s included). The entire process takes 10-20 min. Price for the YotaWerx tune is $500.
You can get more info at www.mobileantics.com. I am based in Phoenix but can cover most the valley. I am in Tucson here and there throughout the year but can also meet up in Casa Grande. I start heading north (Flagstaff area) come June. Hope to hear from you all!
