Oil Change Intervals
Great video, and I just purchased a new 2023 Tacoma TRD Pro and my next service is scheduled for 5,000 miles.
My question is, for a new engine, should the "first oil change" be done earlier (~1,000 miles)?
I assumed the first oil change was critical because new engines may have metal fragments in the oil.
If I want the 1st oil change performed earlier, is this cost on me or can I have my dealer cover this?
I'd like to do the oil changes myself, so any recommendations on oil & filter brands for these 3rd Gen Tacomas?
I change the oil at 1000-miles then at 4000.
So now every time I see 5000 on the clock its time to change the oil,........ no notes needed.
1000 (break in) 4000 (second change) then 5000-10,000-15,000-20,000-25,000 ect.
I am glad I did this,...... extra cost $40 -
I use Toyota Brand 0w-20 ,,,,, $40 a oil change - $6 a quart $4 filter............
Bought my 23 Tacoma in March
1st change was at 450
2nd at 2500
3rd at 5k
Have used a 5k interval since. I generally do maintenance early. Changed differential fluids and transfer case at 2500 as well. Properly checked auto trans fluid as well.
2nd at 2500
3rd at 5k
Make sure you use the correct type....... I do my gear, diffs, transfer and MT every 30,000
Great point….proper fluids are paramount
I generally do differentials, transfer case as well as auto trans every 25-30k
