New toys!
  • Thread starter Thread starter Butch
  • Replies Replies 15
  • Views Views 3K
Butch
Rig of the Month
Just got some new Camburg UCAs and Fox 2.5! Is it the weekend yet?
I was going back and forth on wether or not to do my suspension install.
I've watched so many videos now I'm convinced it will be a fun project.
With a fair bit of cussing.
It’s not bad at all. Everything comes loose easily. If you get stuck, ask on here. There’s a bunch of people on here that have done it, some several times. Cough @UploadAdventure
Unless you’re working on it in gravel, I’ve done enough of that and I don’t want to anymore lol
Just installed some front rear shocks and leaf pack this week. First time, and was easier than I had imagined, though I did leave the UCA stock. I hear that’s a PITA. Figured, what the hell. 🤷‍♂️
Do it. It’s easy! Fronts are real easy. Just remove the 2 bolts on the bottom of the spindle, that helps a lot.
And for the rears, have some good jack stands and a nice jack. To give you some clearance. You can definitely knock it out in a day.
The UCA’s are bad. The long bolt is the worst, coming out. Going in you want to install the bolt the opposite way.
