T
		Tape
possibly a ghost :(
I
SIt happened to me a couple of times,got transmission recalibrated never happened again
No automaticShack is yours a manual transmission?
I just found out its my brakes locking up for some reason
Good to hear you found why. Now to find out...........why! LOL
SI had this happen last week. 6mt here and would not move with clutch in or in neutral. Please let us know what you find!!!
EI always apply the parking brake before taking my foot off the clutch and/or foot brake when parking. My driveway is 32 degrees so it's a requirement to do so, but I was taught to always apply the parking brake and it's a good habit I keep up with in all my vehicles. In this particular instance, the parking brake was completely off and the foot brake was not being touched. I tried to move the truck by letting the clutch out a bit but it stalled. I started the truck again and it moved. So I have no idea.
After some thought and peeking under the hood, I'm thinking it's the electronic brake/clutch control for the PCS.Exactly, it seems when you turn the truck off for a few seconds and then turn it back on it corrects itself so I'm starting to believe it's an electrical deal with the transfer case.
It happened again yesterday and I didn't have the ebrake on and it just completely locks up and you can't go nowhere.
I got like 58,000 miles on the truck now and now I'm changing all the differential fluids and if it happens again I'm selling this son of a bitch.
Yes2019 Tacoma TRD….Auto… I am glad you mention this problem…(at that time fully Stock)..
I live on a dirt road, not flat, when I started up my truck, the tires seem to lock up, I would turn it off and restart.. shift gears reverse and forward…seems like a “glitch”…. Then it seems to work correctly..
Happen on three occasion…. Weird for sure…
If it happens again…I will restart and press brakes once…is this correct?
Aloha
NThanks for figuring that out. I didn't know they worked that way. So if we want all four wheels locked while parked we just have to be applying the brakes when the truck is shut off? Is this a feature or a bug?
I always press the brake pedal before starting so I guess I never would have known about this.
If you use WD-40 instead of air they won't lock up on you again!I’m going to pull the wheel drums off and spray them out with air, the truck has 52,000 miles on it
Then put duct tape to assist the brakes!If you use WD-40 instead of air they won't lock up on you again!![]()
