ICON RXT Squeak Pack...whhhhyyyyy????
CalifExplorer
I have tried everything to silence this ICON RXT leaf pack, which is in the mid configuration. Before I delete the whole setup and go custom-- has anyone figured out a solution? ICON advice was only to make sure it was torqued with wheels on ground, which was done. Grease only lasts a little while. No idea what else I can do.
Some guys have replaced/added pads between the ends of the leaves and that has helped some, but it seems to be the nature of leaf packs after a while.
That said, I much prefer my Deaver pack to the RXT I ran for a few months. I have no weight and found the RXT to be way too stiff.
This stuff also comes in a spray, it will get into spots that thick stuff cannot, BUT it works like the thick stuff.
I have had grease and silicone work then just dry out or get displaced.
Spay it between the plates and on the bushings (rubber / plastic safe) and then brush it or wipe the excess off.
It worked on many things and last where other greases will not,................ might be just what you need.
Thank you so much.
