I got the BRO lean!
  • Thread starter Thread starter Rob Daman
  • Replies Replies 24
  • Views Views 7K
Rob Daman
7️⃣ Connoisseur
So Sunday I decided to install 700 lbs springs on my TRD Bilsteins thinking it wouldn't be too bad since I'm rocking a full steel bumper and 80 lbs Odyssey battery. I did it without a spring compressor (not too fun).
Whelp I was wrong. The BRO lean is strong. The combo of having Decked and hardshell on a AAL doesn't help in back either. My leafs are flat.
I had to adjust my headlights for the time being (pointing way up). I'm actually going to upgrade my leaf pack soon though.
I had the same problem when I installed my 700 lb springs on my 6112s. I added the AAL to the Dakar medium duty pack. This turns it into the "heavy" pack. The front springs settled a bit after a week or so too. With the combo of springs settling and the AAL in the rear pack it fixed the bro lean.
Do you have just the stock leaf spring with an AAL?
These springs I bought were used kings and actually rusty so I cleaned em up and used Steel-it.
Ya the rear is AAL+ stock leaf. I'll have a full pack hopefully by next week. trying to work a deal.
Sweet. I bet that will get resolve the bro lean! Truck looks good as always, really diggin those retro graphics.
The front is at a good height ride now but it will settle. Match the back to that and it’ll look great.
I already have the heavy duty stuff on my truck but I want to make it a little higher to be honest.
fo shizzle!
Post after photos once new leafs are installed! I wanna see how big of a difference there is!
thanks. i bought the springs used and they were actually rusty so I used Steel-It on them so I don't think there's gonna be any settling. i was concerned about my CV boot angles as I wasn't expecting it to be that tall but it's all good.
I'm running a BDS add-a-leaf (from a Colorado) on my stock springs with a 1" block from Toytec. Working great with my Foxs with the Eibach 13" 600lb coils that are spec'd with them. I do have the pre-load maxed on the Fox's though. I may swap out to a 650lb spring in the future if these coils sag.
That's pretty cool about using a AAL for a different vehicle but worked out. ?
i'm trying to get this used leaf pack to me soon before Toyotafest.
Yeah, I was actually the test mule for BDS on that add-a-leaf. They spec it for Tacoma now as well I believe in their new mid travel kit. Hope you get your springs soon!
I need to fix a slight rake in my set up but once go I into overland mode I get a slight bro lean. The stage 2 ivd add a leafs ride great but I need more lift. Maybe the dakar heavy springs.
@Rob Daman see you at Toyotafest
Since we are talking about lean, are the Dakar HDs the most you can get from a leaf pack? Or is there a heavier one from another brand? Would AAL or a block on the Dakar HDs be the tallest/heaviest a leaf pack could be?
There's a guy on TW that sells his own stating it gets 3 inches of lift. not sure on weight capacity.
