High Capacity Fuel Tanks, Larger Gas Tank, Long Range Fuel Tanks,
Q: What is the stock capacity?
A: 21.1 Gallons
Q: Does the fuel data compensate with the trucks computer when going to a larger capacity?'
A: One report: "gauge shows full for about 150ish miles before the needle moves and then it’s like stock"
Q: Do they double as their own skid plate?
A:?
Q: Do they fit both long and short bed designs?
A:?
Q: Do they impact Taco Lean?
A:?
Q: Do they impact clearance?
A:?
Q: Can you still pass inspection with one of these
A: ? (but not really my concern as there is no inspection in most of Oregon, woot!)
Q: Who sells these things?
A:
Rogue Off Road (a T3G Authorized Vendor) Carries the Long Range America 33 gallon version
Larger Fuel Tank.
I believe but cannot confirm that Long Range America is the same as Long Range Automotive out of Australia:
Looks like these guys are selling the same one?
www.mosleymotors.com
These guys sell a bed mounted 15 gallon add on. Not sure how I feel about that:
Another bed refueler
www.transferflow.com
Oddly enough Holly sells one with LOWER capacity...WTF?
That's all I've been able to find so far. If you have more info post it and I'll add it here.
A: 21.1 Gallons
A:?
A:?
A:?
A:?
A:
Larger Fuel Tank.
Toyota Tacoma - 129L Replacement
longrangeautomotive.com.au
2005+ Tacoma Extended Range Fuel Tank — MOSLEY MOTORS
The 32 gallon Tacoma long range tank mounts in place of the original tank. The original fuel level sender is relocated to the new tank. The original fill location is retained and no exhaust modifications are required. Instructions and all mounting hardware and hoses are included. Configurations av
40 Gallon Refueling Tank System
