Happy Trails II
I installed a Yaesu FT-7900 dual band mobile ham radio into our Tacoma.
Power is run by dual fused heavy DC power cable directly from battery to the rear cab. I brought the cable into the cab by putting a small slit in the main cable boot in the firewall near the brake pedal an pulled the cable through.
The antenna is a Comet CA-2X4SR mounted on the left side of the headache rack.. The feed line runs down the rack and comes through a hole I drilled in the lower rear part of the cab behind the left rear passenger seat.
I just put the radio on a movable bracket set on the rear seat. This makes it easy to remove from the vehicle.
The detachable radio operating head is mounted on a MACALLY adjustable cup holder mount. Model MCUP. About $15 on 'zon.
This performs very well. It is a duplication of the installing I had in the Dakota which this Tacoma replaced.
HT
N7BKV
HT
N7BKV
