Electrical Front Turn Signal Bulb Recommendations?
  • Thread starter Thread starter HiterSixOne
  • Replies Replies 5
  • Views Views 1K
HiterSixOne
Just installed the MESO Stage 1 taillight LED upgrade and I'm not sure why I waited. Now looking to change front turn signals to LED. I don't want all new headlight assemblies at $1500, I'd like bulb recommendations from this who have done the swap. Also if you'd include any difficulties or extras you needed to install the particular ones you chose. Thanks.
I have the Stage II and it uses the VLED Triton Bulbs.
So I did matching ones in the front.
VLEDS V6 Triton 7443 - Front
This should be it. Then I eventually ended up with Morimoto XBs.
I did the stage 1 matching turn signal. didn't even need the resistors.
With Meso's involvement, they might even be VLED or made by VLED in the kit.
Usually with same brand quality LED's they match up pretty well. Just don't mix and match in other blinker bulbs.
These are bright, but you know the Tritons are really bright. Comes down to preference of pattern and the way they disperse light.
VLED front turn signal bulbs installed. MUCH BETTER. I know we should support the companies directly, however there was a significant savings purchasing on Amazon. I did not need the resistors so that was great as well. Thanks for the suggestions guys/gals.
