Front end, tracking problem
6362909100
I have a 22 Tacoma Limited I purchased used 9 months ago 36k miles, factory supplied Michelin tires in very good condition The truck drives great, however, it doesn’t seem to track smoothly, I have read on this forum sometime back that increasing the caster seems to help some with bump steer, I’m wondering if increasing the caster my possibly help with my tracking problem?
Having your alignment checked is defiantly a good place to start. I would also check you tire pressures. It might also be a good idea to try rotating the tires to see if the problem might be caused by a tire. I would also jack up each front corner and check for any play. I hope that helps give you a few things to check on.
