Fog light install for 23 SR5
  • Thread starter Thread starter tomoxley
  • Replies Replies 7
  • Views Views 4K
tomoxley
Does anyone know if a 2023 SR5 is pre-wired. I want to order up some led fog lights, but only if the wire harness is equipped?
All the trucks should be prewired, but if you want them to function as factory you will need all the factory components. I believe that's just the fogs, a stalk with the fog switch and possibly adding a fuse or 2 to the engine bay fuse box. I think every SR5 I've seen has fogs already, weird that yours doesn't.
That said, if you are adding fogs, don't bother with the factory ones unless you're just doing it for looks. Their output is trash. I would highly recommend the Diode Dynamics Elites. Their output is tremendous.
Is there a model below SR5? I thought the fog package started with the TDR'S?
Here is the models, the TDR Sport is the model that receives the fog lights
Haha, just noticed my dyslexic abilities! Haha. TRD not TDR. Thanks for the information, I'll look into the installation
