Does Auto LSD mode improve throttle response?
  • Thread starter Thread starter Kuzumonkey
  • Replies Replies 1
  • Views Views 1K
Kuzumonkey
I have a 2020 TRD Off Road with the 6spd manual. I have always been annoyed by the throttle lag combined with a low first gear and lack of low end torque. While playing with the auto lsd mode it feels to me like it changes more than the traction control throttle cut. It feels like it may change the torque curve as well. I wanted to get yall's opinion on if this is true or just my imagination.
Here is what I think I've noticed when changing the traction control modes.
Traction Control on (normal mode) -
1/2 second delay between accelerator pedal press and tach needle movement.
Very slow climb to higher rpm.
Slow to respond to the accelerator pedal with the clutch in while trying to rev match.
Under heavy acceleration, the truck sometimes bogs off the line unless I rev up and dump the clutch.
Noticeable surge in power around 3000 rpm, with an even more noticeable surge at 4G.
A little tire chirp sometimes shifting 1st to 2nd when giving it the business.
Traction Control off (holding the TC button for 3 sec while stopped) -
The same behavior as traction control on, but with a bit more one tire fire.
Auto LSD mode (single press of the TC button, auto lsd light in the cluster) -
Response to accelerator pedal press seems much quicker.
Revs climb faster when rev matching.
I don't notice a surge in power at 3 or 4000rpm. Power and torque delivery seems more linear.
Less tire chirp when giving it the business.
Again, this could be a 'butt dyno reaction to a new intake' kind of thing because I get so frustrated with how this engine normally behaves and maybe I just want this to be true.
Or, perhaps there is a different tuning map for Auto LSD mode to help when you're in a difficult situation and the part time nature doesn't require all of the environmental mothering of the everyday use tune.
What have you guys experienced with this?
