Form Lighting is excited to introduce our New RED Sequential LED Tail Lights for the 2016-2023 Toyota Tacoma!
Looking to upgrade the tail lights on your Toyota Tacoma? Look no further. Introducing Sequential LED Tail Lights from Form Lighting. Not only will you stand out on the road with a more modern appearance, but you’ll also add LED reverse lights, a sequential LED turn signal, and a unique startup sequence.
Modern Appearance. Unlike many other aftermarket options on the market, these tail lights both our red and smoked options were designed with factory-style optics, to diffuse the light in a smooth, even appearance. The outer perimeter of the lamps illuminates a C-shaped bar for running and brake/turn lights. On the interior of the lamp, you’ll find a unique 4-tier LED design, for a truly distinct and premium look.
OEM RED. For those who love that OEM look but also like the modern style of our tail light. You get that OEM-quality red lens that provides a high-end appearance that diffuses the light evenly.
Startup Sequence. These tail lights are packed with modern features, including a unique startup animation. Anytime the running light turns on, it will illuminate in a chasing stacking pattern that is sure to turn heads.
Sequential Turn Signal. The startup sequence won’t be the only thing turning heads. These tail lights also feature a sequential LED turn signal. Any time the turn signal is activated, the red LEDs in the outer C-bar smoothly sequence from the top and bottom, meeting in the middle for a truly premium look.
OEM-Grade Construction. Form Lighting tail lights are built with quality in mind and constructed using OEM-grade materials, including a UV-coated polycarbonate lens, automotive-grade LEDs and optics, and direct-fit connectors. While they may not be the cheapest option on the market, the fit and finish of our lamps are superior to other aftermarket units.
Road Legal. The Red lens color illuminates with red LEDs just like our smoked option and features an integrated retroreflector side marker and running light like the factory lamp. These lamps are SAE and DOT-compliant for on-road use.
Plug-and-Play. Our tail lights for the Tacoma are plug-and-play. They will fit perfectly, without any body gaps. Installation is a breeze and can be done in under 10 minutes. Unlike other options on the market, these tail lights are also fully compatible with Tacoma’s blind spot detection system, if you have it. There are no blind spot system errors, flickering, or hyperflashing!
Click the video below to see HOW to install our 2016-2023 Toyota Tacoma Sequential LED Tail Lights!
Two-Year Warranty. All Form Lighting products are rigorously tested for reliability, and backed by a two-year warranty. The warranty is supported directly by Form Lighting, and any replacement parts, if needed, are shipped quickly from Form Lighting’s US warehouse. On the rare occasion that you may need to utilize your warranty, we try to keep the process as simple as possible - for example, no return usually is necessary.
Do you have additional questions? We’ll be happy to help!
• Reply to this thread
• Send us a direct message
• Email: contact@formlights.com
Are you a US forum member? DM us for a FREE shipping code!
Logan Z.
FORM Lighting
