Will 2020 4runner trd pro suspension fit 2017 tacoma off road?
Ociel85
I have a frien that came up on some 2020 4runner fox coil overs. But i am not sure if they will fit?
Fronts only. Diff suspension set up in the rear
Second question the guy rmthat is giving to me does not know if they are 2 left or two rights. And will it lift my truck at all. I am tring to level it out.
Left or right doesn’t matter. Not sure you’ll see much of a lift in the front.
Is it even worth installing?
From the other forum: Putting 2019 4Runner TRD Pro suspension on my Tacoma (https://www.tacomaworld.com/threads/putting-2019-4runner-trd-pro-suspension-on-my-tacoma.634072/)
Looks like it will be softer than what you have and all 4 corners will fit. Rear needs different lower bushings though. Seems like a pretty simple swap.
I'd throw it on and see how it does, then put a small top hat spacer if necessary (easiest) or hit up Westcott for one of their OEM Pro lift upgrade kits depending on how it sits.
