- Joined
- May 19, 2020
- 1,100
- 2,019
- Location
- Northeast MS
White
Hanging out at the lake.
Bed bushing is worth checking.I have got to figure out this rear end squeak. It's about to drive me crazy. Had it on the lift last week for an oil change and inspected everything. Sounds like it coming from the rear shock area. It started about 3 months ago, I've been lifted since Mar 2022. Not sure if something worked loose or a bushing is bad.
Now that you mention it, I do notice quite a bit of bed flex. I'll start with a re-torque of the bed bolts. Guess I'll go searching today to find torque specs for that stuff.Bed bushing is worth checking.
From Tyler in 2020Now that you mention it, I do notice quite a bit of bed flex. I'll start with a re-torque of the bed bolts. Guess I'll go searching today to find torque specs for that stuff.
Nice. Use any chemicals?Cleaned the engine bay. Not a full detail just getting the mud and crud out. Installed new KC FE 3 lights on front bumper.
Just simple green concentrate diluted 10:1 w/water.Nice. Use any chemicals?
I figured it out last night. Checked some bed bolts and all where torqued. It was difficult to assess where the noise was coming from by my self. Turns out the squeak is from where my leafs bolt to the axle. My middle leaf specifically, which it thought was strange. So I double checked ubolt torque and everything checked out. Hit is with some spray, gave it a couple more ft/lbs on the torque wrench. Nice and quiet on the way to work today.I remember there were some where the front of the bed was moving. Some wear and the composite mount wears away. The metal bushing inside remains the same length. So now the bolt isn't securing anything. Just retaining things together. Maybe this is rubbing? Hopefully it's just this. I would go between frame and bed. Not on the bolt.
Something random I came across while trying to level my bed... Never got it done and being lazy.
Some some made spacers with composite.
Some stacked crap on the bolt.
UHMW Washers
Some went Poly. https://www.mcmaster.com/94045K371/
Hope it stays that way.I figured it out last night. Checked some bed bolts and all where torqued. It was difficult to assess where the noise was coming from by my self. Turns out the squeak is from where my leafs bolt to the axle. My middle leaf specifically, which it thought was strange. So I double checked ubolt torque and everything checked out. Hit is with some spray, gave it a couple more ft/lbs on the torque wrench. Nice and quiet on the way to work today.
How did you apply it?Just simple green concentrate diluted 10:1 w/water.
Just filled a spray bottle, apply liberally, let it soak for about 10 minutes or so and then rinse and repeat as necessary (Remove engine skid prior to this so as not to accumulate crud on skid).How did you apply it?
Thx.Just filled a spray bottle, apply liberally, let it soak for about 10 minutes or so and then rinse and repeat as necessary (Remove engine skid prior to this so as not to accumulate crud on skid).
Dried with leaf blower and let sit for 20 minutes before reinstalling my battery. Total process takes less than an hour with dry time.
That looks hella fun!Spent some time playing in the mud at Citrus WMA FL
