SDHQ A-Pilar Light mounts for 2005-2015 and 2016+ Tacoma
SDHQ OFFROAD
sdhqoffroad.com
GILBERT, AZ
Website
sdhqoffroad.com
PRODUCT OVERVIEW:
SDHQ's Tacoma A-Pillar Light Mounts are designed and built in house to ensure they are the best fitting, highest quality a-pillar mounts on the market. With our brackets there is no need to cut or trim the cowl like you do with other kits on the market. All brackets are designed to work with OEM Hardware. Easily attach a set of Baja Designs Squadron Pro Lights
KEY FEATURES:
  • No Drilling Required
  • Bolts directly to Hood Hinge
  • 4 MIL-Spec Vibration Dampeners for Zero Vibration
  • 3/16 Thick Steel Plate Construction for Durability
  • Built to handle the weight of larger Lights
  • Mounting Slot for Multiple Light Choices and a Customized Fit
https://sdhqoffroad.com/collections/sdhq-built-a-pillar-light-mounts
