- Joined
- Jul 12, 2018
- 218
- 272
- Location
- Sparks, NV
- Website
- www.relentlessfabrication.com
UPDATE 2/27/19 - SLIDERS HAVE BEEN REMOVED FROM OUR SITE TO FOCUS ON REDUCING BUMPER LEAD TIMES. OUR APOLOGIES ABOUT THE INCONVENIENCE.
One of the most vulnerable parts of your vehicle when going off-road is your rocker panels. Be it a rock, log, branch, or even just that dirt pile you’re driving over, anything hitting your lower rocker panels can cause some serious and unsightly damage before you even realize what is happening. Factory or aftermarket steps installed leave a false sense of security and before you know it a rock will push the steps in leading to more damage to the vehicle.
What you need is some affordable protection available in versions that either bolts or welds directly to your vehicle’s frame! Relentless Fab rock rails will do the job through years of abuse and punishment, all while complementing your vehicle's looks. Not only will they fend off damage from trail obstacles, but they can also serve as a hi-lift jacking point anywhere along their length. Further, they can be used as steps to get in or out of the vehicle or to aid in accessing a roof rack.
Relentless Fabrication - 2016+ Tacoma Bolt-On Rock Sliders
Key Features:
- USA 2x2” square .120” thick steel tube and 1.75” x.120" DOM round outer tube structure.
- Oversized 3/16” thick gussets and CNC cut and formed 1-piece continuous frame plates.
- Standard straight outers with 15* up angle, optional kick-outs or filler plates available.
- Bolt-on design that lines up with all factory frame holes! Optional holes in the bottom of mounts for additional holes if the utmost strength desired, and some factory holes may need to be made larger for our oversize 1/2" hardware.
- Powder Coated option is Matte Black Only
- Sold as a pair of rails (driver and passenger sides, side specific).
Starting at $639!
Key Features:
Starting at $639!
