Thank youBad seal. Also, the outer bearing. Check and see if there is a lot of play in the CV at the axle. If so, get the ECGS bushing and seal replacement kit.
TIP: If you have trouble getting the removal tool to fit, grind it down a bit on the back side so that it will fit. The one I used would not fit without modification.
-M
Thanks for the tip, I will keep it in my mind.Bad seal. Also, the outer bearing. Check and see if there is a lot of play in the CV at the axle. If so, get the ECGS bushing and seal replacement kit.
-M
Thx for info.had to replace axles needle bearing and everything that needs to replaced.clam shell sleeve .it cost me but I lovecthat truck.Bad seal. Also, the outer bearing. Check and see if there is a lot of play in the CV at the axle. If so, get the ECGS bushing and seal replacement kit.
-M
