BARE Outfitters Co. - ARB Twin On-Board Air Compressor Sale
Needing a solid solution to your on-board air needs? Add some insurance and ease to your next off-road trip by upgrading your rig with an on-board air compressor.
ARB is the leader in overlanding vehicle accessories. When it comes to solving the need of a dependable, strong air compressor, they didn't disappoint.
Providing optimum power, the ARB twin motor design delivers class-leading air flow for fast inflation purposes. Constructed of lightweight, high-strength engineering grade materials, it incorporates quality components for quiet operation and extended durability. The twin motors incorporate internal thermal protection against extreme temperature damage while a heavy duty in-line maxi fuse for each motor provides professional circuit protection. Available as either a portable kit with a 4L air tank, inflation accessories and a durable carry case or a vehicle mounted kit with associated wiring loom and mounting hardware.
ADDITIONAL FEATURES
FREE SHIPPING in the US, tracked and insured.
https://bareoutfitters.com/products/arb-twin-on-board-air-compressor
ADDITIONAL FEATURES
- Designed for inflating Tires and air locker activation when used in conjunction with optional accessories
- Suitable for many air tools when used in conjunction with a 4L air tank (optional with on-board models)
- 100% duty cycle
- Sealed for moisture and dust resistance
- Hard anodized cylinder bores for reduced friction
- Teflon impregnated carbon fiber piston seals for maximum trouble free life
- anodized mounting bracket dissipates heat
- Integrated pressure switch, relays and IP55 (waterproof/dustproof) brushless fan cools electronics, motors and cylinder heads
- Over-pressure safety valve equipped
- On-board model available in either a 12V or 24V configuration
