waiting for the email from them letting me know it is back in stock myselfFinally got around to get the volume fix from Meso installed, should have been like his from the factory but oh well putting Meso's kids through college pretty much.
Mounted this 30" Baja Designs S8 light bar last week on the CaliRaisedLed brackets but the wiring didn't show up until the other day, so I got it wired up this weekend. I need to angle it up a bit and rewire the backlights to go thru their own relay, but pretty happy with how it turned out. Looks really clean and subtle too.
I should have never got my sliders Raptor lined. Might have to get them powdercoated.RCI rock sliders and they look amazing!
do you have a link to this?Adjusted
They're available all over the place. You never see them on sale so I jumped on it when showstoppers had their 21% off sale last month. Here's the link tho: https://www.showstoppersoffroad.com...driving-combo-pattern-s8-series-baja-designs/do you have a link to this?
There's a DIR cable. Disable in Reverse, it cuts out the plate lights when in reverse so there's no wash out. Definitly worth checking out.had one of my LED bulbs in the license plate lights go out (put it in back in '15 when the truck was brand new) replaced both w/ some new dimmer VLED ones. less washout in the rear camera at night now. I guess 8 years is pretty good for a bulb.
I'm a little lost. I get what it does. But if the new bolts are there, how does the bumper fit on there? What did you fill the holes with?Beefed up the front bumper mounting points with 1/2 inch grade 8 hardware and 3/16 steel reinforcement plates from Overland Outfitters. View attachment 63473View attachment 63472View attachment 63471View attachment 63475
The bumper fits exactly as before. The holes on the winch plate of my SSO bumper were large enough to allow for adjustment so the larger bolts fit without any issue. I would imagine most aftermarket bumpers would be similar.I'm a little lost. I get what it does. But if the new bolts are there, how does the bumper fit on there? What did you fill the holes with?
That all-window auto switch is awesome. Is it pnp and does it auto up as well?very slow weekend but was able to install the AJT Designs oversize cup holder, the minimalist V2 key fob from Meso and the all auto window switch for all the windows. Why there’s only the front 2 from the factory baffles me.
Glad you figured out the speaker issue. Electrical things suck.Yesterday I fixed a speaker that was cutting in and out. Apparently I had a bad crimp from the initial install in March and it just started acting up. Good to go now.
Rad about the switch module. Will definitely have to add that to my want list.Glad you figured out the speaker issue. Electrical things suck.
Yes it’s plug and play and works flawlessly. Auto down and up yes.
I actually did this, but I completely chopped off the frame ends and welded in new 1/4" plates, I also ground down to make them fit flush with the rest of the frame.Beefed up the front bumper mounting points with 1/2 inch grade 8 hardware and 3/16 steel reinforcement plates from Overland Outfitters. View attachment 63473View attachment 63472View attachment 63471View attachment 63475
Overhead switch looks awesome. Is the 2-switch panel pnp or did you have to cut and glue?Relocated traction control to overhead using the Meso 2 switch panel and an extension cable. I was prepared for a fight, but it wasn't bad, just a bit tedious routing the cable. Made room to add future switches although I am not sold on keeping rockers, but they are easy to connect to the KC Flex Era 3's for now. Some type of switch panel will probably be coming in the future.
View attachment 63522View attachment 63523
View attachment 63525View attachment 63527
100% PNP. One of the reasons I went with the 2 over the 3. Definitely have to cut and modify to fit 3.Overhead switch looks awesome. Is the 2-switch panel pnp or did you have to cut and glue?
Need one? I have the file for this.Overhead switch looks awesome. Is the 2-switch panel pnp or did you have to cut and glue?
