Understandable
I’ve always found the tuning process to be very confusing. Flashing the truck (the final step) is fine, but everything leading up to that part was always a mess, IMO.
Understandable
Did you type this correctly? Should it be orange adapter with the software?orange adapter with the adapter
Meant to say cable, my bad. I'm retarded.Did you type this correctly? Should it be orange adapter with the software?
As long as you have the new info for VFTuner, you're good to go. I did the same $79 upgrade.I have the master key already. So I can use the old orange device that I already have?
Edit: I don’t even know if I put the Tactrix adaptor on this order. Let me see…
Sounds like it.Sweet! So this whole time I could’ve done this already but I was needlessly waiting for nothing because I’m an idiot.
Looks like I’ll be flashing my truck tomorrow!
Yeah, I didn’t get those files anyway. Mat just sent me my master key with instructions to download the software on the homepage of his website. And that should be all I’ll need.Sounds like it.
Usually most people would wait for the Final/2.0 tunes from VFTuner to send the link to their ECU ID. But if you're flashing Valley Runner, you don't even need those files because you can just flash Valley Runner.
Correct. It looks like you’re good to go.Yeah, I didn’t get those files anyway. Mat just sent me my master key with instructions to download the software on the homepage of his website. And that should be all I’ll need.
I know there is an intake/exhaust option. Sorry if I asked before. Is there anything tuning-wise to improve with a Y-Pipe?Correct. It looks like you’re good to go.
Setup the software with your master key, install the latest OpenPort drivers (VFTuner help tab at the top of the software has a link for it), connect your cable and flash the VR files we made for your truck.
I did the KD Max Tune. What a difference. It shifts like it should have from the factory and very much like my 2008 4Runner. The Toyota shift algorithm is horrible and why they continue to stay with it is a mystery. It doesn't help gas mileage and, I would think at some point, cause more wear and tear on the transmission. I have approx 1500 miles on the tune a mixture of highway, local, and one towing trip. The tow load was about 3500lbs and handled it much better than it did prior to the tune.Did you buy OVTune? If so, how are you liking it? Any bugs?
I know it is on my eventually list, but to be honest, I don't even hate the stock tune as much as most people. It definitely could be better though.
We have eliminated the exhaust option with the v2.1 update.I know there is an intake/exhaust option. Sorry if I asked before. Is there anything tuning-wise to improve with a Y-Pipe?
That's separateI’m leaning towards a KDMAXX or Valley tune.
My Toyota dealer turned off the seatbelt chimes on my truck. Will this setting be lost if a new tune is flashed to the ECU, or is it a separate thing altogether?
What's your ECU version? If it's up to date, then no. If you're not updated and your provided tune is an updated version (likely), then yes.Last question before I flash (hopefully)…
Does this thread about ECU TSB updates pertain to me? Or can I basically ignore the info in this thread?
ECU TSB Update
Hey, All. In an effort to get you to the info, I have created spoiler buttons for some of the subjects. Hit them to get all of the hidden info! This...www.tacomaworld.com
Will my ECU version show on the software? I haven’t gone through the instruction manual yet, I’m just getting prepared.What's your ECU version? If it's up to date, then no. If you're not updated and your provided tune is an updated version (likely), then yes.
Yes, you'll hit Prepare ECU with an internet connection (required) and it'll tell you your ECU versionWill my ECU version show on the software? I haven’t gone through the instruction manual yet, I’m just getting prepared.
I know with the original OVTune, you’d get your ECU version from the software.
Holy crap. It’s immediately obvious I’m on my new @TermLimits tune, the second I hit the skinny!Can I use the software to see the tune that I flashed just to ensure it did change? “Read ECU” wasn’t working for that.
Nope.I got the wire and flashed the truck. About to go test drive it.
Yup.USB mini B?
Glad you enjoy it! Even with those 37” tires it’s definitely an improvementHoly crap. It’s immediately obvious I’m on my new @TermLimits tune, the second I hit the skinny!![]()
I believe we received your request through the website not too long ago as well. I'll reach out to some of my Texas and surrounding area installers and see what we can do for you.I’m looking for an OV Tune on my 2021 TRD Off Road. Any shop that does this near San Antonio or Austin TX?
That's odd. So from that it sounds like the tune processes speed data from a speed output source. So it's not actual speedo, but a "tool".I flashed one of the OV Tunes when the truck was still stock and really enjoyed the tune. After the lift, 34s, and 5.29s I flashed the truck with the new corresponding OV Tune and was hugely disappointed with its performance. Not long after that I installed the Rough Country inline speedometer calibrator and immediately the tune starting working like it should.
Not sure if this will help anyone out there, but the difference in how the truck operated was immediately noticeable and made both purchases worth it.
I have put about 2,500 miles on the truck as of the @TermLimits tune and here’s my update.Holy crap. It’s immediately obvious I’m on my new @TermLimits tune, the second I hit the skinny!
I believe these trucks calculate speed at the wheels. That being said, if ODO is ticking over much faster than it should you may have a faulty wheel speed sensor.That's odd. So from that it sounds like the tune processes speed data from a speed output source. So it's not actual speedo, but a "tool".
I think my bike updated the odometer without calculating my sprocket change. Like it racks up miles faster.
Does the odometer go by actual or what it thinks? I guess if it's programmed for factory settings, does it go by number of rotations?
So bigger tires means you'll be going faster. Does the odometer rack up faster then? Does it get factored into miles until empty? Shower lower mpg?
@TermLimits - Can you answer this for me?Overthinking.
I asked this over on the tune thread, what version of OV 2.0 were you running beforehand?I have put about 2,500 miles on the truck as of the @TermLimits tune and here’s my update.
Unfortunately, moving from the OVTune 2.0 tune to this one was a pretty significant downgrade for my use case and I need to flash back to OVTune when I can (but I don’t have my original file anymore).
The Valley Tune does pack more of a punch when you tap the gas. It feels like it might be fun for mobbing through the desert at 10-30 mph. If that’s what you’re looking for, you’d probably enjoy it.
That wasn’t what I needed though. I was looking for a tune that cruises well at highway speeds and might have better mpg than the OVTune I was using (not because I expect decent mpg with my truck, but spending less time stopping for gas is nice).
Comparing the numbers, the OVTune was better for me— someone living on the road while traveling the country:
OVTune 2.0 city mpg: 11-13.5
OVTune 2.0 highway mpg: 13-15.4
Valley Tune city mpg: 10-11
Valley Tune highway mpg: 8.5-10.3
OVTune 2.0 RPM at 65-80 mph: 2,000-2,500
Valley Tune RPM at 65-80 mph: 4,000 almost constantly
OVTune 2.0 gear hunting compared to stock: Great
Valley Tune gear hunting compared to stock: Poor (similar to stock)
This feedback is based on a very heavy truck (still need to weigh it), 5.29 gears, 37” tires. My truck isn’t meant to have nice numbers to begin with but the tunes are relative and the differences feel huge.
