Sold Toytec Aluma 2.0 kit
gelsi2033
5️⃣ Platinum
FL
2021 TRD OR DCSB Auto
Silver Sky
$650 - Shipping to lower 48 included in price.
Used for 8k miles/5 months. Installed 9/2021 at 3k miles. Removed 2/2022 at 11k miles. Some cosmetic dings (nothing that is visible when installed on truck).
Preload set to 2" of lift.
Spanner wrench included - adjustable 1" to 3"
Sway bar relocation brackets included
Wheeler super bumps front included
All hardware included
Oh man this is super tempting. Let me check a couple of things, I may swing it!
Do you have any install pics? Did you go a full leaf in the rear? I'm just curious what the lift will look like with nothing in the rear.
Responded to your PM. Here are some pics of it installed. If you are looking to level, this will do it. If you want to retain factory rake you would need to add something in the rear. Center hub to fender measured ~22.5". With 1.5" progressive AAL in rear, I retained full rake. Pics are on 265/75/16. Of course you can adjust and add or remove preload as you wish.
