Kjack48230
Just wondering if it's possible to have fog lights installed on a new 2021 SR 4x4 crew v6 if it didn't originally have them.
If you remember how, that would be very helpful, thanks.You can add in fog lights to your Tacoma using factory wiring and a switch. I should of made a write up last year when I did mine.
Does your SR have the factory switch? I'm assuming you added your own afterwards with an aftermarket switch? Some models are pre-wired and some are not. Will depend on that. Was yours pre-wired? What Fog Lights did you install?Is there a way to wire fog lights so they go out when the high beams are turn on for a 2021 Tacoma sr
The SR is pre wired for fog lights. Find the y connector needed to plug into the line and your fogs will be activated by the factory light switch.
Aftermarket:
I would try wiring the fog lights to be triggered by the factory low beam. Since the low beams shut off when you hit the high beams it should carry over.
Relay:
30 - Power/Battery
87 - Fog Lights
85 - Ground - I'd put the aftermarket fog light switch here.
86 - Factory Low Beam Fuse - Add-a-fuse at the fuse box. Existing factory fuse will go on the bottom.
This retain the factory low beam function.
The fog light switch is just powering the fog lights.
The low beam switch is what will be turning the fog lights on and off.
No factory switch, no factory harness, and the low beams stay on when the high beams are turned on
I mean... anything is possible if you put your mind to itJust wondering if it's possible to have fog lights installed on a new 2021 SR 4x4 crew v6 if it didn't originally have them.
"off-roading"Just be aware, not all aftermarket fogs lights are legal? ( legal for street driving) Look for the ones made and design for on street driving. If you want for driving on streets ?
The rest is for off roading.
Aloha
I have a 2014 Toyota Tacoma 2.7 liter pickup. I would like to have fog lights. There is a cut out in the bumper. Will there be wiring already there so I can just
plug them in?
