- Joined
- May 5, 2021
- Messages
- 247
- Reaction score
- 459
- Age
- 37
- Location
- California
- Website
- www.coryinmotion.com
Cement
Hey guys! Unfortunately selling the truck. Life! All of these parts are off the truck and are now for sale. Don't hesitate to reach out.
I can also offer checkout through PayPal so you can use their available PayPal financing options for the expensive stuff.
Located in Inland Empire, CA
Here's a few shots of the truck for reference.
Parts and prices:
Locked Offroad full 2.5" extended travel coilover kit (front and rear, stock replacement) - $2000
Accutune Tubular Spherical Front UCA's - $750
- Perfect condition
https://accutuneoffroad.com/product...H_yZuu7OXuOmDkMZVg-zMVVKc9cSQUD4aAk4FEALw_wcB
Accutune N98 (J66 hybrid) leaf pack - $800
Accutune U-Bolt flip with Progressive bump Stops - $300
4 Wheel Parts Heavy Duty Rock Sliders with Kickout - $750
(4) BORA 1" Bolt-on Wheel Spacers - $200
- Currently installed on the truck
(4) Spidertraxx 1.25" Bolt-on Wheel Spacers - $200
- Available to ship now!
SOLD Bakflip F1 Tonneau Cover - $SOLD
Diode Dynamics SS3 Fog Lights - $200
Cali Raised Hidden Light Bar Brackets with Light Bar - $125
(2) Trigger One Bluetooth Relay - $50
(4) Classic 1997 spec Rays Power Volk 2pc wheels (16x7, +25 offset) with Yokohama Geolander 255/85r16 tires @ 50% tread (plus one spare unmounted tire, same size) - $2750 OBO
Thanks for looking!
Parts and prices:
- Great performing kit, comparable to FOX
- ~5,000 miles
- 650 lb springs, ride height set for stock weight (~2.25" lift in front)
- No wait, available now
- Perfect condition
- Bushings still in excellent condition
- ~2.25" lift on stock weight truck
- Rides like stock but slightly softer, good for stock weight or +300lb/towing
- Bump stops in perfect condition
- Height set appropriately for this setup (can be changed, contact accutune)
- Light scratches from bushes, etc
- Never touched a single rock
- Excellent condition
- Perfect condition, all hardware included and not damaged
- Bolts straight in, no modification to the truck needed
- Relocates factory tie-down bars so they can still be used
- Holds up to 400lbs on top of cover
- Direct bolt in
- 1 repaired bracket
- Amber, DOT Approved (won't blind everyone on the road, still works amazing offroad)
- Will come with all wiring and necessary hardware
- High Quality Amazon brand lightbar (Spot focus center lights, spread outer)
- Directly replaces most light and accessory relays
- Allows control of accessories via bluetooth on your phone!
- Removes necessity to run wiring and switches in the cab (clean install)
- Ultra light, similar to modern Rays Volk wheels at 16.5lbs
- Practically unattainable in this color and condition
- Fully restored, all new hardware
- Same as stock wheel offset on 3rd gen, but needs at least 5mm spacer to clear brake calipers
- If using 5mm spacer, shouldn't rub at all on cab or chassis!
- Currently setup on truck using 1" spacers as seen in photo
Thanks for looking!
