Looked pretty good to me. You rinsed off the hood first which is correct. A lot of people go HAM on the first thing they see (which is typically the engine cover) and then get everything dirty again when they notice the hood, or they forget to do the hood entirely.
Pro tip - cover anything you are worried about getting too wet with a plastic bag/saran wrap, then spot clean separately with engine detailer. I typically do this to aftermarket parts and any sensors that look delicate.
I also like to put a towel on the windshield so I donāt get it too filthy.
One thing I will say though: I would not wash a running engine. I donāt see any benefit to it first off (especially considering you talked about potentially disconnecting the battery), but itās already hot af and more heat will just dry out your products, and most importantly by running the engine you significantly increase the risk of the intake or PCV or something drawing water into the system. You also start drawing electrical from your alternator to critical components like the ECU and anything attached to your battery.
