CaliRaisedLed Lighting Products
CaliRaisedLED
caliraisedled.com
Cali Raised Led is now offering 3rd Gen Tacoma (2016+) brackets for your vehicle. Our company is located in California and all of our BRACKETS we make is made in the USA.
About Our Brackets
The design and material thickness we have chosen, is engineered to be as strong as possible without increasing the cost of the LED bracket. We use 1/8” cold rolled mild steel, pickled and oiled, with a tinsel strength of 35-55,000 KSI. In addition, we have strategically placed bends to allow the bracket to be free from deflection and vibration.
CaliRaisedLed 2016 3rd Gen Light Bar Brackets
2016-2018 TOYOTA TACOMA LOW PROFILE DITCH LIGHT BRACKETS $54.99
With Harness $69.99
With 18W 3x2 $115.00
With 20W 2x2 $125.00
With 18W 3x2 Amber $135.00
With 27W Side Projecting Pods $135.00
2016+ TOYOTA TACOMA 32" LIGHT BAR LOWER BUMPER BRACKETS $59.99
With 32" Combo Beam $269.99
With 32" Spot Beam $269.99
2016+ TOYOTA TACOMA FOG LIGHT LED POD REPLACEMENT $99.99
With OEM Plugs
With 18W 3x2 $139.98
With 20W 2x2 $149.98
With 18W 3x2 Amber $159.98
05-2018 TOYOTA TACOMA 52" CURVED BRACKETS $99.99
With 52" Combo Beam $389.99
With 52" Spot Beam $389.99
2016-2018 TOYOTA TACOMA HIDDEN GRILLE LED LIGHT BAR MOUNTS $39.99
With 32" Combo $239.99
With 32" Spot $239.99
05-2018 TOYOTA TACOMA BED CHANNEL STIFFENERS $99.99
Led Light Bars 5D Optics
7.5" 5D- 69.99
13.5" 5D - $110.99
21.5" 5D - $159.99
31.5" 5D - $239.99
41.5" 5D - $259.99
51.5" 5D - $289.99
51.5" Curved 3D - $369.99
16W 2x2 Pod - $29.99
18W 3x2 Pod - $39.99
18W 3x2 Flush Pod - $44.99
Does the switch panel kit have a relay block or would I still need an inline relay
I received mine today and they are nice. No relays needed and looks to be same size as competitors. I too am decoding where to install it caise i cant find any information if it fits in the competitors cubby mount.
You said no relays needed. But my rigids have relays. Can you please further explain
BED STIFFENERS READY AND LOOKING GOOD
No they do not. Your rigids come with a relay harness which is an optional product. More than likely its just a piece that plugs into the bar correct? The purpose of a relay is to send low voltage signal to a switch inside your truck. The switch controllers like caliraises and simila do this themselves eliminating need for relay. So you cut off or simply disconnect the relay and cut plug at end of led lightbar off exposing just the red and black wires. So you would just run the hot from your lightbar to the input of the switch controller (inline fuse provided with product and then run the ground from the lightbar to a grounding block. Buy it and ill walk you through it. You wont regret it
Right on. After I pay off the rest of my Pelfrey bilt stuff here in a few weeks I’m totally game
I got caliraised. For $199 you get basic on/off. No strobe. That one is like $599
@951_yota I’ve Been looking at this panel for a week now, however I currently only have 1 auxiliary light. I feel like this Switch panel is a gateway drug to more lighting and accessories to control.
Lol i have ditch lights, bumper bar and behind grille so that leaves 5. Just as u mentioned i had to fill it up lmao so i just got front and rear anytime camera mod and a cb so now i have two spots. They fill up fast trust me. In hand the product feels nice and i dont regret going this over the more expensive one. It just has less bells and whistles
Roger that, appreciate the feedback.
Thank you for helping out and giving additional info!
About Our Brackets
With Harness $69.99
With OEM Plugs
7.5" 5D- 69.99
13.5" 5D - $110.99
21.5" 5D - $159.99
31.5" 5D - $239.99
41.5" 5D - $259.99
51.5" 5D - $289.99
Can ou confirm these lo pro ditch brackets are different than the ones i purchased about 6 months ago that stick out sideways a tad? I am looking for something a little more lo pro but cant tell from pics. If so im in for a pair and will be ordering
https://caliraisedled.com/collectio...ducts/2016-toyota-tacoma-ditch-light-brackets
Hello,
This is our newer version of our 3rd gen ditch brackets. Compared to our older ones they are super low and have a better design.
IF you have any questions let me know.
Thread stickied
If your looking for ditch lights check out our side projecting pods!
Great customer Picture with our molle system
