Welcome
Cali Raised Led
www.CaliRaisedled.com
Phone (714)-752-6315 info@caliraisedled.com Instagram @cali_raised_led
05-2021 Tacoma Skid Plates
Before you hit the rough terrain, protect your vehicle with Cali Raised LED Skid Plates, that can take a hit and is built to last through the toughest conditions. Guarding the underside of your outfitted off-road vehicle as you adventure in the great outdoors, these skid plates are custom-made to fit your vehicle so you can focus on the trail ahead. These are a universal fit between 2nd Gen and 3rd Gen Tacoma’s. Crafted from American 3/16 Steel. The front skid plate is 100% bolt-on and is installed with zero modification to your truck. Using a combination of factory hardware and grade 8 hardware for high-quality fit. Choose from RAW or Powder Coat depending on your desired look and use.Cali Raised Led
Features:
- 100% bolt-on option, no modification required.
- The finish of choice, mix and match, no rules.
- Easy installation, read our installation instructions or watch the installation video below for a step-by-step guide.
- Crafted by American Welders, professional finishes to protect from any corrosion, with the chosen finish.
2005-2021 TOYOTA TACOMA FRONT SKID PLATE
https://caliraisedled.com/products/2005-2021-toyota-tacoma-front-skid-plate
2005-2021 TOYOTA TACOMA TRANSMISSION SKID PLATE
https://caliraisedled.com/products/2005-2021-toyota-tacoma-transmission-skid-plate
2005-2015 TOYOTA TACOMA TRANSFER CASE SKID PLATE
https://caliraisedled.com/products/2005-2015-toyota-tacoma-transfer-case-skid-plate
2016-2021 TOYOTA TACOMA TRANSFER CASE SKID PLATE
https://caliraisedled.com/products/2016-2021-toyota-tacoma-transfer-case-skid-pla
2005-2021 TOYOTA TACOMA LOWER CONTROL ARM SKID PLATE
https://caliraisedled.com/products/2005-2021-toyota-tacoma-lower-control-arm-skid-plate
2005-2021 DCSB AND AC TOYOTA TACOMA FUEL TANK SKID PLATE
https://caliraisedled.com/products/2005-2021-dcsb-and-ac-toyota-tacoma-fuel-tank-skid-plate
2005-2021 TOYOTA TACOMA REAR SHOCK SKID PLATES
https://caliraisedled.com/products/2005-2021-toyota-tacoma-rear-shock-skid-plates
