Where and why not?Ok next noob question. Read somewhere that since I have crawl control I can't use diff spacers. Does that mean I need to keep it at 2.5"? TIA
Guess it needs compressed a little or it's way too tense to rotate.If a strut is assembled, can you turn it after assembly to get it to line up? Or does it just have to be lined up before assembled?
So I’m looking to lift my 21 trd off-road. I’m looking at the readylift 3”f/2”r with 17x8.5 et0 with a backspacing of 4.75”. What’s the best size all terrain I can fit that’s under 35
265/75r16 or 265/70r17Has any put 255 /85/16's on there stock suspensions. Ho do the look/ride. Im not ready to do a full lift but would lik the biggest tires that will fit stock.
Looks like their "leveling" kit, with slightly taller springs in the front to raise it level with the rear. Still has stock shocks, and based on the picture, you must have a TRD Off RoadHello I recently purchased a new Tacoma with a lift kit installed from the dealer. I don't really know much about lift kits and I was hoping someone could give me some information on what was done to the truck. Thank you. I can provide more picture if needed. View attachment 45133
And yes you are correct about trd off road.Looks like their "leveling" kit, with slightly taller springs in the front to raise it level with the rear. Still has stock shocks, and based on the picture, you must have a TRD Off Road
That's what was done to the rear.
so that's a 1.5 inch block. You've got a 1.5 inch lift. Not a bad set up. Budget, but it works. Your rear leaf springs will be fine if you don't put much in it on a regular basis, but they'll sag after a while if you keep it loaded. Your ride in the front will be a little more stiff than usual, but shouldn't have any long term detrimental effects.That's what was done to the rear.
Hello, what is the tallest 18 inch tire I can go with if I put a 2 inch lift?
I have 17's now
Thank You!!Awesome. Thanks for the information.
Thank youTire Size Fitment and Lift
I figured i would throw an end all be all in here to settle the age old question "what tire size will fit". This is my personal opinion and experience, taking into consideration measurements of the wheel well with the cab mount in mind. You do not have to follow this chart if you have plans to...tacoma3g.com
Check this thread out. Should answer your questions quite well.
In general, a 31 inch tire will fit on your vehicle with a 2 inch lift, 32 if you're ok with a little rubbing, 33 if you're ok trimming a bit to get it not to rub. That would be 265/70/18, like this one: https://www.tirerack.com/tires/tires.jsp?tireMake=General&tireModel=Grabber+A/TX&partnum=67TR8GRATXRWL&vehicleSearch=false&fromCompare1=yes
I have a 2020 trd pro, and when stock the nose did not dive significantly when braking. I was very happy with the pro set up, just can't leave things stock for more than a year or two.I have a question. Maybe it’s been asked before. I have a 21 off road. Have any of you installed the Fox Pro OEM shocks on a TRD off road ? Did you still have the front nose dive when braking ? Are you happy with the new Pro set up ?
Thank you for that info.I have a 2020 trd pro, and when stock the nose did not dive significantly when braking. I was very happy with the pro set up, just can't leave things stock for more than a year or two.
Nope. We have a "post any photo of your Tacoma" thread that serves that purpose.Is there color specific photo threads anywhere?
Yes there are. I know there is a thread called "Show off your magnetic grey metallic" for sure bc I've posted in it. I'm pretty sure theres one for each color. Use the search bar and type inIs there color specific photo threads anywhere?
Yes. There's also a protective 'film' over it to protect against scratches and rock dings.I should have asked this a while ago. Is the bottom part of the doors suppose to feel “rough”
