Wheel fitment
Brycegreg15
I have a stock 2023 off-road tacoma I’m currently looking at the kmc km236 tank wheels they 17x9 with -15 offset. Planning on running 32” or lower tires what do I have to in order for these to fit. I don’t mind chopping inner liner I just don’t want to rub suspension or have to do body mount chop or relocation.
With that offset and tire size you should generally be fine not to rub. You should not have to chop anything for a 32" depending on width, but all these trucks seem to be different, so it's really a game of chances. With a 32" though, I would imagine the most you might have to do would be get aligned at a competent shop and have them bump up your caster to be a bit more positive than factory spec, but throw em on and see where you're at.
FWIW I'm a 17x8.5 -10 with a 285/70 (33") and had to CMC and get UCA's that allow me to push my caster to 4 degrees, but now I should have clearance to fit a 285/75 (34") which will be my next tire size. Also not sure what tires you were looking at, but don't get Ridge Grapplers, they suck in every environment.
Awesome thank you for the response. I forgot to mention I’m still at stock height still trying to figure out suspension as well.
17x9 with -15 offset on a stock Tacoma is pushing it, especially with 32s. You'll almost certainly need to trim the inner fender liner, and maybe even the pinch weld. 32s might rub at full lock depending on the tire's sidewall. A small lift (even just a leveling kit) would make a huge difference in preventing rubbing on the suspension.
Yea I agree at the very least I’d need to throw on a leveling kit and maybe adjustable control arms for the time being until I figure out what suspension I want to put on
The KMC KM236 Tank wheels with a -15 offset and 17x9 size should fit your 2023 Tacoma with 32" or smaller tires, but you may need to make a few adjustments. Chopping the inner fender liner can help avoid rubbing. To prevent suspension rubbing, make sure there's enough clearance, but avoid body mount chopping or relocation for a cleaner fit. I remember when my younger sister was applying to colleges, and she was stressed about writing an impactful admission essay. She came to me for advice, but I felt unsure about how to help. While searching for solutions, I stumbled upon https://academized.com/write-my-admission-essay Academized. Their admission essay service was exactly what she needed. The writer took her rough ideas and turned them into a beautiful and compelling story that showcased her strengths. Seeing her excitement and confidence grow was priceless. She not only submitted her essay on time but also received offers from her top choices.
How is everything going?
Edit: Thank you for replying.
Okay so I found another wheel that I’m looking at because the kmc wheel I was looking at is beadlock and thinking about I really don’t need a beadlock wheel for my means. I’m looking at either black rhino arsenal or the armory both are 16x8 with -10 offset. If I were to run 265/75r16 on these wheels would I rub at stock height?
