Redline Hood Struts Installed--Mission Accomplished
Happy Trails II
Took about an hour to install the Redline hood strut kit. Max lift option. I found the instructions clear. The process simple. And the product good quality. Used a tapered reamer to slightly enlarge the drilled holes for the rivets. Happy with the results.
Thanks for all the advice from this forum
HT
Can you get a side profile shot? I wonder how much space there is with the high lift for ditch lights.
Hood struts rock but should have come with the vehicle like most other Toyota's. Sad it's an aftermarket fix, but it makes a world of difference, and is worth the price if you do any work under the hood, or hook up a compressor.
