60K MILE MAINTENANCE - HELP WITH PRICES / PRIORITIES
youcanrunnaked
Here's what my dealer replied with when I asked about recommended service at 60K miles:
Oil and filter change $130
Tire rotation NO CHARGE
Transfer case drain and fill $380
Rear differential fluid drain and fill $380
Front differential fluid drain and fill $380
Transmission fluid drain; clean and inspect the pan, reseal and fill $380
Test coolant $160
Test brake fluid $160
Test power steering fluid $160
Engine air filter inspection $55
Cabin air filter inspection $55
Full vehicle inspection at no charge
SPARK PLUG REPLACEMENT IS NOT REQUIRED UNTIL 100K MILES
These are their book prices; I can get them discounted, depending on what I have done. In the past, this dealer has been fair with me (e.g., oil and filer for $79; a set of four AT tires at 30% below retail). I am wondering what a fair price for each service (of the total service) should be.
I thought the 3d Gen Tacoma has iridium plugs, and those are good for 100K miles. However, spark plugs at 60K miles is in the OM. I've seen it said that this is a conservative recommendation to guarantee Toyota's EPA compliance, and the dealer says 100K miles is fine. I'm inclined to agree, but would appreciate input from owners.
I'm thinking coolant should be good to 100K miles. Maybe the South Florida heat requires a test now, though? Regardless, the test / inspection prices seem way off to me.
I can probably test / inspect ps and pb fluids, and coolant, myself. I don't have the test strips for this, but getting them and DIY seems like a better strategy than spending $480 (or even half that) to have a technician test them.
I can look at and replace as necessary engine air and cabin filter myself, but IMO they should inspect them as a courtesy, not for $110.
The fluid changes also seem a bit high. I am not sure that I have the tools, talent, or workspace (other than a sloped driveway) to do the drain and fills. Dropping the transmission pan is another thing I'm hesitant to do myself. I'm also not sure what the fluid and filter costs are, as compared to having the dealer do them. If the price difference between materials and dealer service isn't that great, I would just have them do the work. Would like to get advice on this.
My truck is at 62k and is in the shop right now for other reason. They brought up the recommended service and mentioned the plugs, they were quoting me something like $700 for the job. Yikes! They are supposed to give me the full list of recommendations when I pick it up tomorrow. I'll post it here so we can compare numbers. I have a friend with a shop so I plan to do it all myself.
If you do your own maintenance,
oil 5K - Diffs 30K - MT first time 30K then 50K (same with transfer case)
Coolant and plugs 60K or most do at every 80K (depending on how you drive and where)
Shops charge WAY too much for maintenance and repairs.
I can see needing to bite the bullet for repairs as vehicle lifts and special tools are required
PLUS, knowledge beyond maintenance and a tech stream (computer reading device) is often unavoidable.
But oil changes and fluid changes and even spark plugs can be done by the owner.
If you are mechanically inclined just do it this is a pretty good Tacoma help site.......
Its basic stuff, the site is good at telling you the tools you will need.
BUT if you are not good with tools or have never worked on cars,................ dont touch it.
Bolts and screws can be damaged, and the threads stripped, you can get over your head fast.
Repairs are expensive but having someone fix what you have screwed up or damaged can be REALLY expensive.
Besides no mechanic likes to fix someone's mistakes. Its hard to warranty work and most mechanics will just take off everything and start over which is more time and money.
The list of dealer repairs for 60K above gets close to $2000,...... all can be done in one afternoon for a couple hundred bucks.
But you need tools,...... never buy cheap ass tools. They will damage bolts and screws or break themselves.
Tools are an investment; knowledge is power and fixing your own stuff is gold!
95% of mechanics first learned the basics from their father or a friend. (I hope these days have not passed us by)
Fact is vehicles today have become more complicated and technical than even and even the best driveway mechanics find themselves scratching their head and go to the dealer themselves as they know your vehicle is no place for experimental try's or learning something for the first time.
You can do maintenance! This will extend the life of your vehicle and save money while feeling good about it.
Here is your $380 rear differential fluid change in 2 minutes.
Source: https://youtu.be/qyauqDyk7cg
Here are the prices I was quoted, as promised:
