Rompin’ Taco - OR 4x4 Long Boi 🌮
Beamtech LED headlights and brights. These puppies have no fans! Nice and quite!
7a316823-8e05-48c2-81d1-fbe420fc3bd7-jpeg.23258
New updates:
picked up some maxtrax in turquoise and made custom mounting brackets for the Prinsu only cost about $15 for the supplies to make the brackets out of aluminum angle iron. Also, I had to adjust the light whip to match the new maxtrax.
Did some maintenance recently at 70k:
  • Oil Change (done myself for the first time after having the dealer do it every time) - on the filter cover someone had over tightened the drain cap so the whole thing came off and oil went everywhere. I now need to buy a new cap as I was unable to loosen the drain cover for future drains. I’ll also be getting a fumoto for future self service.
  • Greased the propeller shaft. Super easy to do.
  • Installed a bully net in the bed to act as a baby gate while tail gating
  • Installed some KC Rock Lights more photos to come
Suspension update: I had the front coils adjusted to max height. The truck is sitting pretty close to level now. I did have to take it to get an alignment which helped reduce just about all rubbing.
I've been a bit busy with buying a new house, moving and selling my old house and fitting in some upgrades to the truck here and there. So, heres a list of mods I've recently done to the truck.
  • OV Tune for 33 inch tires, 87 gas, and AGM battery update.
  • Rigid Industries D-Series Pro SAE Fog Light (Selective Yellow)
  • Southern Style Off Road Slimline Stage 2 Bumper
  • Square One Creations Frame Caps
  • Warn VR Evo 12s Winch
  • KC HiLights RGB Rock Lights
  • 12 Volt Socket in Bed with Volt Meter and USB Ports
  • Relocated KC 30" Light Bar behind the grille
  • Relocated winch controller behind grille
  • added spacers to emergency brake lines and flipped passenger bolt to prevent waring on leaf pack bolts
  • Greased the front UCAs and replaced a bad zerk fitting
Suregery/Facelift Excess Materials
New Garage space with room for a rooftop tent! oh yeah!
Ended up relocating the remote resi as I was experiencing a bit of tire rub on them while on the trail at full lock and flex. This should be a lot better.
