L
Lava road
possibly a ghost :(
Anyone install these for there 4x4 and use it for off roading.. Roadmaster Active Suspension system..
Part # RAS4514-sat or RAS452-sat…not sure of the difference…both cost $499.00 shipping not include…
I had one RAS-active on my 2002 Nission Exterra…purchase this SUV use and it came with it….never did pay attention..but look cool…motor die and I sold it…
One video show a one increase in height after install.
2000 lb. Capacity, reduces sway, improves traction ,east to install…. I had traction control lift single spring install on my Exterra and 2002 Ford ranger…you could feel the difference in traction grabbing right away… nice! This acts like a traction bar and helps prevents axle wrap..
Your thoughts?
Aloha
After further research. The RAS is for stock rear springs…. With my Icon Add-a-lift…which has a bar across the top of rear spring…where spring is attach…this RAS will most likely NOT fit….
I may go with either a one inch lift block or 2 inch instead…I want the rear to have a higher rake..due my fiberglass camper and heavy gears for over night camping and fishing…
Your thoughts?
Aloha
