PCS sensor recall | Page 3 | 3rd Generation Toyota Tacomas — Tacoma3G.com
PCS sensor recall
Oregon 3rd Gen
T3G Level: Gold
T3G Supporter
Eugene, Oregon
First Name
Matt
T3G #
2,262
I need to post this here. If you are not having issues with your PCS. DO NOT PERFORM THE RECALL, unless you have a stock grille. I wasn’t having issues before the recall which flashes an update onto the sensor. Now my Pro Grille and sensor are giving me issues. This is what I get for being proactive. Long story short. No issues= don’t do recall. Issues and stock grille = go ahead
Under no circumstances is the professional advice, just what I have experienced talking to multiple dealers
cocodataco
T3G Level: Gold
T3G Supporter
First Name
Jeff
T3G #
1,015
Took care of my PCS yesterday, which I did notice intermittent issue with it disconnecting. Dealership took care of it, but I did sign a liability release form recognizing that because my truck is lifted that the PCS may not capture obstacles due to the height being adjusted. They were unable to calibrate the height because it was "unknown".
But they did take care of me and installed the foam piece.
danwray
T3G Level: Bronze
First Name
Dan
T3G #
1,373
Do they need to remove the grill to perform the recall? I have some lights wired that would make it difficult to remove, that I would probably take out myself before I take it in if it does need to come off.
crfloria
T3G Level: Bronze
T3G Supporter
Jacksonville, FL
First Name
Ryan
T3G #
2,276
Ya Arlington Toyota here in Jacksonville told me because I have an after market grill and bigger tires that they could do the upgrade/recall but if they did they would have to disable it all.
I said no thanks!!😡
crfloria
T3G Level: Bronze
T3G Supporter
Jacksonville, FL
First Name
Ryan
T3G #
2,276
I've never seen a letter on a recall before. Service advisor usually look for recalls when you drop in for service and ask if you want it done, but if parts need to be ordered, then they call you to reschedule when it comes in. Or you can call for an appointment to get it done if you don't happen to be dropping in.
I received a letter a couple weeks ago.
danwray
T3G Level: Bronze
First Name
Dan
T3G #
1,373
I called them to ask and they said they normally would remove it, but they had enough room to do it while it was still on the truck. I took it in before work the other day and they fixed it up, no problems. I will say, the fix doesn't look all that impressive, it's just a big sticky foam piece on the back of the radar. I don't really see it keeping much water out, so you might not be missing much if you can't get the recall done.
danwray
T3G Level: Bronze
First Name
Dan
T3G #
1,373
I might just be paranoid, but the more I think about it, the more this seems like a fix designed to keep it from malfunctioning before the warranty runs out, but not permanently.
Oregon 3rd Gen
T3G Level: Gold
T3G Supporter
Eugene, Oregon
First Name
Matt
T3G #
2,262
I’ve just given up hope. The sensor shuts off after twenty minutes of driving. So I’m past caring. Want to unplug and see if that stops the light from coming on
MicTee72
T3G Level: Bronze
First Name
Mike
T3G #
3,888
Yeah mine is doing the same thing. I can use it initially if I want to but like you said 20 minutes or so it alarms.
