Old guy novice, second Tacoma, looking for advice from you pros, and fellow owners, 2017 trd sport, long bed | 3rd Generation Toyota Tacomas — Tacoma3G.com
Chaslyon
T3G Level: Bronze
Ocean city Maryland
First Name
Charlie
T3G #
3,824
Howdy, bought my second Tacoma, 5 months ago, Black, 2017 Trd Sport , longbed. I need a dive from you pros, I don’t have an unlimited budget, but would like to start, in order, suspension, 2-4 inch, tires next, really wanna stay in like a 31, inch or so, and I live at the beach, Eact Coast, so need more sandy gear. I have been looking at ICon, and Fox, also Toy o parts for suspension lift. I have been to 2 shops, both have said that my model Tacoma is a tough fit. Would like to hear from you all. Thank u
Pinion
T3G Level: Bronze
T3G Supporter
First Name
Drew
T3G #
3,099
Welcome,
31.5” will fit with no lift or rub, I had those on my truck before lift with no issues
Thing to keep in mind, bigger tires need a re gear and one of the best mods I have done. Not cheap but if you going even to a 33, regear will definitely help with lag and a lot of back nd forth shifting
Also with 33’s is the cab mount chop. Ome have some nice setups for suspens as well. And with you, undercoating, these trucks have no rust protection underneath
I lived out in East Hampton for a long time and these things rust in the driveway on the ocean
Good luck and have fun, a lot of good resources here
SDCementTacoTruck
T3G Level: Silver
San Diego
First Name
Reuben
T3G #
391
Tires: 31" (265/75r17) tires should fit with no problem and no lift. If you go to 33's 285/75r16 or 285/70r17, you would need a lift (see below). I have 33's and only tire rub was as full lock and extreme tire compression while off-road. to achieve this you do need to have alignment adjusted outside factory spec by pushing the wheel forward a bit. I have this with no wear issues. To avoid any rubbing issues 100% stick to 31" tires or cab mount chop (CMC).
Lift: There are may options for you desired height... if you are trying to keep to a budget try OME or Bilstein adjustable shocks... both options installed are around $1000. If you go with king, icon, fox, you will start around 2500.
I hope this helps, If you have any specific questions, let me know. Good luck!
  • Thread Starter Thread Starter
  • #6
Chaslyon
T3G Level: Bronze
Ocean city Maryland
First Name
Charlie
T3G #
3,824
I actually have 265 75 17 now, a decent toyo tire, I am assuming stock
