- Joined
- Oct 21, 2019
- 504
- 911
- Location
- Ohio at the moment
Magnetic Gray
M100 military resto-mod.
Fully disassembled, sanded, primed, and coated with Raptor Liner.
33x10.5-15 BF Goodrich MT
Axle and wheels have been sanded, treated, and coated with POR 15. Wheel faces are also topped with Raptor. Bearings are packed and ready.
All new suspension and hardware. That includes new springs, shocks, 1.5in lift H shackles, new zeros, Grade 8 and stainless hardware throughout.
Upgraded LED lighting with smoked lens lights, new wiring, and 7 pin connector to operate backup floods and provide auxiliary power if needed as well as electric brakes if new owner wishes to swap axles.
No hand brake as the previous owner removed it. Some drill holes left from POs rack install. Left in place for use in later modification needs.
This is an extremely solid trailer. All the hard work is done and it's ready for you to outfit with your personal touch and make your own.
$3,700 obro (obro stands for Or Best Reasonable Offer)
Located in Ohio
Located in Ohio
