Base on my experience, I recommend the XenonDepot bulbs if you're just wanting to swap out bulbs. They have HID and LED.
I had the XD HID Lows, LED Highs with the Baja Designs Fogs.
Can get 3 sets to cover your lows, highs and fogs.
Morimoto XB Headlights if you can spend the money. Upgraded to this because I was having a Toyota problem.
I have all of these, minus the redundant items. Other just listed as options.
Seems like a lot but I found it to be worth it in the long run. Which I should have stuck to my buy once dry once ideology. But I bought, sold, lost money, upgrade, repeat...
Morimoto also has bulb kits called the 2-stroke or something. Did not have Morimoto bulbs.
Also:
Morimoto expands its complete housings from Fogs to Heads and Tails and now to Mirror Lights for your Toyota Tacoma!
www.morimotohid.com
If you want to get fancy, grab a set of Baja Designs Squadrons. They have a fog light kit. Huge difference. Just sold mine preparing for my new bumper and I lost so much visibility at night. Already ordered another set that will fit the new bumper.
@ragofabrication is having a crazy sale right now. Might have to email in.
info@ragofabrication.com
There's also Morimoto and Toyota LED Fogs out there. But I highly recommend the BD. Difference is crazy.
If you want to go even further
https://mesocustoms.com/ for your interior lights. Sign up for the notifications and grab them when they come in stock.
A sleek and functional map light replacement. New injection molded housings for an OEM fit and finish. Like the Ultimate dome, these replace the OEM clear lens completely. Includes a custom MESO PLUG" T10 bulb adapter for a 100% plug and play installation. Available in White or Red Fits: 2016+...
mesocustoms.com
SINGLE COLOR. No buttonThe brightest and baddest dome light on the market! With close to 100 LED's, this thing is BRIGHT. New injection molded housings for an OEM fit and finish. This is not your conventional single bulb LED swap, but a complete panel that replaces your original clear lens...
mesocustoms.com
NEW DESIGN! The Ultimate dome light which has been a hit is even brighter and better. The V2's now have a low profile tactile button in the center which will toggle the lighting mode. DUAL COLOR: Switch between RED(center) and White(outer) LEDs DUAL BRIGHTNESS: Switch between HIGH output and...
mesocustoms.com
We've had great feedback with our regular White and Red Ultimate map lights, but these combine the best of both worlds. DUAL COLOR! Utilizing new high power LEDS and redesigned array. Switching colors is simple with the exposed tactile button on the front.
mesocustoms.com
They also have a nice upgrade for the factory tail lights.
Description Introducing the newest version of the Total Tail Light Kit. This is a 100% plug and play harness AND LED conversion. Not only are they brighter than stock, but it relocates the turn signal to the bottom section and makes it Amber in color. The brake light is also expanded into a...
mesocustoms.com
Description Taking the Total Tail Light Kit to the next level with double the brightness! Enter Stage 2. This kit uses all upgraded LEDs from VLEDS. Be warned.. this is bright! This kit includes the following: 2 wire harnesses with all OEM connectors 4 VLED 7443 Red bulbs 2 VLED V6 Triton...
mesocustoms.com
Offers Puddle Lights as well.
Description Will work with 360° camera mirror models The puddle pods are a simple and convenient addition to the exterior of your Tacoma. They were custom designed to fit the 3rd Gen mirrors with OEM fit and finish. Each side houses a high output LED pod that will illuminate the ground when you...
mesocustoms.com
Your vanity light is: 6612F
I couldn't stand that and had to swap out all the lights.
