InexperiencedWiseman
So if I’m undertstanding right, there doesn’t really seem to be any good options at the moment aside from Deaver leaf packs, not including the J66?
I certainly don’t have the longitudinal (or breadth) of experience as some of the other members on here, but my personal experience with the Dobinson 111-R (mid range ~600lb constant load rated) leaf pack has been excellent since I installed them about a year and a half ago.So if I’m undertstanding right, there doesn’t really seem to be any good options at the moment aside from Deaver leaf packs, not including the J66?
When underloaded (250 pounds, leer cap and some gear) they ride a bit stiff and gave me approx 3 inch initial lift in the rear. 2.75” after settling last I checked. With closer to the 600# they ride beautifully (I have Elka 2.0” rear struts FWIW). The most I’ve carried fully loaded was around 800lb and I still had 2” lift and tapped the bump stops once on the highway on a big old dip.
I did the poly bushing and greasable pin kit also from dobinson, and just bought new OEM shackles rather than try to get the old pressed bushings cut out. I get a little squeak on the passenger side from time to time but not obnoxious amounts and from what I’ve read with some other options, it’s better/best case scenario.
I would definitely recommend Dobinson’s packs based on my experience.
I’ll have to crawl under the truck and take a look/photo of mine. I frankly don’t remember. That looks gnarlyDobinsons are a better design than Dakars, I like Dobinsons design overall, appropriate main leaf thickness, except they STILL have the shackle rubbing issue because the 2nd leaf extends inside shackle (carryover from Aus. Hilux design) and may cut up the shackle when heavily articulating.
Other thing it only has a 1/4 wrap on front eye like stock springs, not full military wrap for severe duty
This was Tyler's 112 pack with stock hangers, not sure if Dobinsons has since revised this. If they say they have, I'll need to see a pic of current production to believe them
Good to know. I looked earlier—shackles are intact and the leaf pack doesnt really resemble the picture above so I wonder which version I have. Either way, I don’t wheel the truck crazy hard so I’m probably in the clear.Originally the 110 and 111 had plenty of clearance to shackles, only 112 had interference. Then Dobinsons made 2nd leaf extend inside shackle on 110 and 111 as well, but it's not as bad as pictured, still rubs tho, and I suspect worse if you wheel them hard
Is this normal for Deaver? These are Stage 1.
I continue to snap the anti friction pads and my overloads seem to slip out of alignment when under heavy articulation. Nothing terribly concerning but the pack is only a year old and I have replaced 4 anti friction pads and had to loosen everything up, realign and then torque everything down again at least twice.
I make sure all shackle bolts are 89 ft# and under load when tightening and check my u-bolts often at 80ft #.
No complaints about the ride height, ride quality and hauling capacity.
Is it normal to just expect more maintenance when going with an aftermarket leaf pack?
Amazon. Funny thing is the ones I have replaced seem to fit better than the ones that came on the pack.I have the same springs and to my knowledge I haven't broken any friction pads yet and I've had them on the truck for over 2 years. I did just notice that I need to straighten out those shackle clamp things. I'm going to be doing a good pre trip maintenance in the near future so I'll double check my friction pads. Did you get the replacements from deaver or another source? I have been wanting to get replacements anyways.
How long is this 15% sale good for? When does it expire???After 2 years of testing on dozens of trucks, Archive Leaf Springs are live and right now on SALE 15% OFF
They've done very well when directly compared to the best leaf springs on the market
100% MADE IN USA with US steel. Please choose to spend slightly more than the overseas options and support American craftsmen
Tacoma Leaf Springs 2005-2023 MD HD XD Archive Garage
*T3G members start conversation for 5% discount Archive Tacoma leaf packs are designed by Archive for severe duty off road travel! -Made in USA with 5160 US steel, tip insert pads, FULL military wrap (only brand with wrap in HD/XD range), bolted spring clips -Top quality POLY bushings are...tacoma3g.com
