When I replace the boots, I usually add some ball joint chassis grease to the inner ball joint. Should I also
turn the steering wheel completely right and add grease to as many of the rack splines/teeth that i can reach?
note these pics are not mine, just pics I found on internet to illustrate: imgur.com
Also, can I use standard worm roller clamp for the large end?
