FRONT DIFF ACTUATOR
Taco16
5️⃣ Platinum
Has anyone had to replace or repair the front diff actuator? Mine has the flashing green 4x4 light and wont engage 4 wheel drive. Dealer has told me its the front diff actuator not working. They want over $2000 to repair it. They say the front diff has to be completely removed, i did see a 2nd gen video of it being removed without removing the diff anyone know if its the same. ANY HELP WOULD BE GREATLY APPRECIATED !
Diff shouldn't be removed only drained . How did they conclude you front actuator is out , how much do you use it ,do you do alot of water crossings ? Warranty not covering?
They said the breather hose to the actuator was not connected due to my lift it pulled it off! :oops: I checked that hose prior to dropping off at dealer it was on connected but missing the little end breather. I did do 1 water crossing in within about 2 hours after i had this issue start. They are denying warranty because of all the mods lift and they said i altered the electrical in the truck. Not true did not touch a single while. All lights connected on its own switch wiring!
I have been through two front diff actuators now. My local service center has blamed water damage, how water is getting in is a mystery to me, I don’t do any serious water crossings, yet water can somehow get in, and corrode the actuator, twice now. I’ll be taking a look at the “breather tube” tomorrow and start considering my options to extend or replace the stock setup. Anyone else having this issue?!?! There can’t be only a select few facing these problems. I’ve been through two of them in less than a year!
I'd take it to another dealer get it done and see if it happens again perhaps they are doing somthing incorrect during the install ,extended any breather higher and make them more secure is also a great thing to do
So i did get a new OEM actuator. Apparently The breather hose on the actuator came unplugged some how and i did suck in some water into actuator! Here is what a little water can do! It had been only a month ago when this happened!
New unit works great no more issue's!
Seems like might be time for some breather mods now, never even they they had a breather on the acuator
I do have all the breather mods done . Apparently the hose has a connection somewhere near the front diff going into engine bay,at that connection is where it pulled off going to actuator into engine bay.
My lights is flashing. Parts has to be ordered via dealership. 50/50 under warranty. Check out attachment pretty dumb what they said. I’m responsible if it’s damaged wth
So you did install it yourself, then? Is it easier than expected?
I ended up having a shop do it. I didnt have time they had it done in about 3 hrs according to the manager. Only cost me $280 but it saved me from time off at work and i had a trip that same weekend. It was worth it.
I've replaced mine three times. There's no cure for it getting water in it.
If you go in water it will fail eventually. The breather tube is not the best idea. It is however, attached to a hard line that runs to the top of the engine bay. So at least they were trying to keep it our of the water. The actuator is not waterproof and deep water will cause failure. It's not hard to replace and I've covered mine with flex seal, put clamps on the vent line and dielectric grease on the connections. So far so good. I just hate that in the back of my mind I know it will eventually fail again anyway.
Ah yes, the classic "engineered to fail eventually" part. Gotta love modern design.
I have the issue of "2 wd to 4wd failure" on my dash and the yellow flashing hazard light. Any ideas?
I believe the most common cause of this is a ADD (Automatic Disconnecting Differential) actuator failure. It could also be a low voltage issue or a few other things.
I would check the following:
Check for codes (AutoZone will read you codes for you if you do not have a code reader)
Check your batter voltage while under load (turn on every electric thing on your Tacoma and see what the voltage is with everything on)
Listen for noises when you try to shift into four when drive. Do you hear ant motors trying to engage?
Chances are you will need to replace your ADD actuator to get back to normal 4X4 operation.
I hope that helps.
