Engine Codes
MJ'sTacoma
5️⃣ Platinum
Rig of the Month (2x)
Age
23
FL
2018 SR5 DCSB Auto
Barcelona Red
2018 Toyota Tacoma 3.5L
I recently had my check engine light on, The truck was giving the following codes:
P0598 - Thermostat Heater Control Circuit Low
P0037 - O2 Sensor
P0057 - O2 Sensor
P0441 - EVAP System
I spent about two hours on google and found no info about these codes happening on other tacomas.
I replaced both O2 Sensors and the thermostat, reset the codes and nothing happened, Still had a check engine light.
Turns out it was an add-a-fuse I had in the main fuse box that was causing the ECM to have some sort of glitch.
I wanted to post this so anyone looking for those specific codes can check the fuse box before having to unnecessarily replace parts.
P0037 - O2 Sensor
P0057 - O2 Sensor
P0441 - EVAP System
Was it Raptor Lights? 😁
Shot you a message about the O2 sensors if you got stuck with them.
It was the alpha rex headlights!
Did you check all the wiring? Figure out what exactly caused it?
Removed the add a fuse, it was like magic, the wire seemed to be ok, no tears or chafing
Efi no.4
It had a 5amp add a fuse
