- Joined
- May 1, 2018
- 339
- 476
- Location
- The Gate City
Silver Sky
I don't think it's going to be difficult at all, even with my circumstances (how my rears are powered by my amp via OEM wiring).:Waiting to see how easy/difficult this is to do
The following posts are going to be process and updates of progress for the install of the Kenwood DMX905S.
For prep work, last night I removed the Beat-Sonic CS6EP unit from my truck. This plug and play unit worked very well however, the DMX905S comes with 2 camera inputs, and they are both "on demand" as well as the rear camera turning on when truck is put in reverse.
I also removed the dual USB from the glove box, the splitter from the OEM input, and put the OEM USB back in the dash panel. Because I can listen to the iPod via AirPlay, I will be storing it in my armrest console, plugged into the USB outlet I installed in there, and will have my micro thumb drive plugged into the OEM USB spot.
The following items come in today:
E-Brake Bypass
Maestro HRN-RR-TO2
Stinger RCA cables
Maestro ADS-MRR
Metra 40-LX11 Antenna Adapter
Kenwood Excelon DMX905S
I'll start my capping and soldering tonight using this notes page I made to put up on my work bench
Currently, my rear speakers are powered by my amp (Arc Audio xDI 850.5) via a wire harness that plugs into the OEM wiring. In order to continue using the OEM wiring for those speakers, I will need to solder the speaker wires coming from the amp for the rears to the Maestro wire harness (circled in yellow).
The soldering will not be completed tonight, as I am still waiting for new speaker wire for the rears, as well as new remote turn on wire.
I'm hoping to do the actual install either Saturday or Sunday.
I also purchased a new tool for setting my gains on the amp. In the past, I used a DSO Mini-Oscilloscope to set my gains in a safe and responsible manner. I've decided that I want a PHD set up (push here dummy), and ordered a Steven Meade Designs DD-1 distortion detector to make this process more painless, and because it will get a lot of use (my kid's cars will be getting carplay/android auto when they purchase, as well as my cousins will be using it as well).
I will probably be doing a little more clean up with my previous install in the truck as well (tons of extra wire in there that can be shortened).
