33’s 2” leveling kit
Lreed2487
So was wondering if anyone knows if you can run 33s and a 2” leveling kit without rubbing. Currently have 33’s on it and I barely rub on the front part of the inner fenderwell and just a little on the upper control arms if I take a driveway too fast and too much of an angle. Had planned to purchase the lift kit but unfortunately life happened so that money went else where after I bought the wheels and tires. So now trying to find something to get me by for a couple months but not break the bank.
The 2" leveling kit should be better, with the right alignment adjustment, you should have minimal rubbing.
I'm running a 2" Rough Country Leveling kit on a '19 4x4 Sport with Toyo Open Country A/T's 265/70r18 and the only rubbing I had was with the front air dam when making turns. Removing the air dam solved that problem.
