Zach's Debt Plan
Smitty
Age
21
SE Connecticut
2017 TRD OR AC Auto
Blazing Blue Pearl
Just thought I'd jump on the bandwagon with a build thread! I'll have to find some pictures from my phone to post on here from when I first got the truck :)
Current Parts List:
- Black TOYOTA grille
- Caliraised LED lightbar under grille
- Front and rear Wheelen blue emergency lights (for volunteer firefighting/EMS)
- TRD front license plate
- Baby Yoda dash decoration
- Front dash camera (forgot the brand)
- Tonneau soft bed cover
- Black tailgate inserts and blackout emblems
- LED interior multi-colored floor lights
- Auxito LED fog lights and headlights bulbs
- Stock rims, running BF Goodrich's All Terrains
Obviously it isn't much, however I do have a very expensive list of things I wanna do! :)
Quite a few pictures here but shows the slow progress overtime. Plus I included some of my favs :)
Can’t wait for more upgrades!
Future To Buy List:
- Roof rack with LED lightbar included
- Ditch lights
- Rear ditch lights to attach on front of bed (closer to cab)
- Leveling or lift kit
- Slightly bigger tires
- Running boards, mainly for my shorter girlfriend :)
- Front and rear bumpers
- Some minor interior stuff
Not too sure what else I want to do on the interior as of yet, I do have a dashcam inside tho!
If people want, I can post exactly what I have and from where if interested! :)
Kind of a list for me so I don't have to keep finding these things :)
(Links attached in most)
Exterior Lighting:
- Ditch lights (Lasfit Pods or 4Banger and Switch)
- Rear ditch lights (Same as hood ones, different mounts needed tho, not sure what will work yet)
- Puddle pods cause why not (MESA Customs and Caliraised Switch)
- Headlights (After Market) or (Alpharex)
- Taillights (Alpharex)
- 3rd Brake Light (Lifestyle)
- Switches
Body Work:
- Roof rack with lightbar (Victory 4x4) (Caliraised Switch) --- Probably not getting a rack, doesn't look as good on the access cabs...
- Side lighting on roof rack (Victory 4x4)
- Running boards (OEM Running Boards for Access Cab)
- Front bumper (C4)
- Rear bumper (Pro Series Bumper)
- Lift kit (Looking for 2" maybe, would do roughcountry.com)
- Air compressor (Rogue Offroad)
- Mudflaps (Rokblokx)
- Exhaust (MBRP)
Interior:
- Chrome delete kit (MESA Customs)
- Dome lights (MESA Customs)
- Rear domes (MESA Customs)
- Lower switch panel (MESA Customs)
- Left side panel (MESA Customs)
- Armrest storage (Victory 4x4)
Grand Total (roughly) as of right now is about $7,000 for everything listed so far.
If anybody has any better recommendations or reviews on products I listed please do let me know! :)
Exterior Lighting:
Body Work:
- Lift kit (Looking for 3" maybe, would do roughcountry.com)
Interesting. Go inactive on the forums a little and I miss out on something new. First time seeing the 3rd brake light.
A couple things, I'd avoid CaliRaised, Rough Country and Pro Series. I'm also weary of Alpharex. CaliRaised and Rough Country commonly slightly modifies then rebrands the cheaper almost mid-grade stuff from China. Then mark it up.
Pro Series is just an inferior bumper. Lower and thinner grade steel, bad coating and fitment issues. It'll wear and rust out over time. Morimoto > Alpharex. Prices are competitive to each other. Morimoto just has better quality. There have been reports of Alpharex housing melting. Unsure if it's just the outside elements or electronics heating up. Morimoto has reputation and more experience in the industry.
I've become a huge advocate for buy once, cry once. Optimize value for your money. Go for quality. There have been multiple times I'd get something because it was good enough. But I wasn't satisfied. So I'd buy something nicer that I considered an upgrade. Sold the first thing at a loss. Shortly later only found out there's better, repeat. Buy, sell at loss, buy again for more, sell at a loss. Get something good. Doesn't have to be the best. But so your research. Get good advice. Know who gives good info.
Lift.
Just an opinion of mine, spacers should only be used for small lifts (1"-2.5") or leveling out.
Tacomas lean to the driver side due to having more weight on that side, driver and gas tank. So it's basically common practice to run a 1/4" or 1/2" spacer on the driver side front. I forget if the spacer size equates to the height being doubled or halved.
I would completely avoid the rubber gasket spacer if you just wanted a little lift. Explanation on your other thread. If you're doing it yourself and don't have a spring compressor, it's not even worth it. Compressing the spring was probably the worst part. The clamps and even the full compressor stands that can be rented and even bought on Amazon were not capable of compressing mine. It bent the Amazon stand one. The ones from the auto parts stores just made me nervous. I've done a lot of dumb unsafe things, but this one made me tap out. It scuffed up the coating on the springs and I ended up getting them powdercoated.
Just top hat strut spacers. You just drop out the shock assembly, set it on top of the top hat and reinstall. So much easier and cost effective for a baby lift.
Next option. Bilstein 5100's and a AAL + driver side front spacer. (OME Spring) - This is pretty much a starting standard with Tacomas.
I feel the Bilsteins improve the ride quality of the truck. Looks like you have an OR and I believe they are 4600/4700 shocks. So it is an upgrade. I've never tried them with the factory springs, so I can't give you feedback on that. 5100's have a collar that you can set the front ride height. You would disassemble your factory shock and use the spring. Raising it does compress the spring a little, so it does become stiffer. But it will be smoother and a much better option over just spacers. For AAL, any general 1.5" AAL will do for the rear.
To improve on this, you could grab new springs for the 5100. OME makes a bunch for different ride heights. Benefit of an OME spring is that it's designed to be compatible with the Bilstein 5100 shock without raising the collar for height. It's designed to give the lift and retain the ride quality.
If using an OME spring, don't raise the collar. I feel the 887 will level it out. Some have gone with the 888. Always consider the vehicle settling over time. So you could lose up to .5" in the long run. Also depends on how much weight is added to the vehicle. I added a front bumper and it did weigh down the front about .5" with the 887. 888 springs have a higher compression, so that would be the option if you're adding a bumper.
After that, you're looking at Bilstein 6112's, Kings or Icon. I believe this would be the best progression lift wise. From eh (spacers) to good.
I did the 5100 front and rear/887/Icon AAL. Added some weight. Wanted more. Settled on the 6112 front, upgraded Bilstein springs, 5160 rear and kept the Icon 1.5" AAL. I went with the Bilsteins again because they were the compromise between value, dependability and performance. It appears one side of the truck is lower than the other and I'm seeing that to be common. Some leaf packs take that in consideration and have side specific packs. So that's what I want to do next.
Current Parts List:
Haha, I'm right there with you bud....Don't have a lot as of yet but my list is quite extensive lol.
Alright, time to update this instead of editing my OG list...
Exterior Lighting:
Body Work:
Gear:
Interior Work:
I'm not as worried about the interior as of right now. Probably won't go thru with all of the interior stuff.
The 👀 means ordered or ordering soon btw
